Where the motor screws loose?
After you tightened them will the motor still move without resin in the petri?
Without power turned on does the arm assembly move up and down relatively easily by hand?
LittleRP not lifting when it has resin in Petri
Re: LittleRP not lifting when it has resin in Petri
I feel like something is loose, can you check / tighten the 2 m5 buttonhead screws that fasten the top plate into the two rear extrusions? They are the screws on the very top of the machine.
How big is the object you are trying to print? Is it something you have printed before?
If you have or know someone who has experience soldering, you can can try removing the shield and resoldering (just hitting the current solder with the tip of the iron to remelt the solder) that go to the 4 pin motor connector and the 4 pins of the stepper driver that they connect to. Might be an intermittent connection there, if a stepper has a wire unconnected it can run rough.
Scatterplot
I'm no expert but I believe that you can damage stepper motor drivers by unplugging a stepper while it's enabled.
Have you verified you can jog the system with no resin in it since you've tightened screws/checked cables/etc?
