CastSolid resin used in kiln burn-out or in vulcanized molds?
smsla
Postby smsla » Mon May 18, 2015 2:45 pm
The body of this post is a re-post [for the most part] from my reply to the post by JSmith172 at viewtopic.php?f=19&t=2733
If an artist is able to create a vulcanized mold with any resin -- why the hype over so-called 'CASTING' resins? Meaning that if I print a resin piece then vulcanize it -- then cut around the mold, and even into the resin and manage to create a usable vulcanized mold from ANY printable resin, and then inject some wax into the created mold and run off as many copies of the original as the mold will allow, why would I need to buy expensive Casting resins? Am I just purchasing this expensive goop so that I can burn out the printed resin with a kiln only if I wanted or needed to, vs running multiple copies of wax version using the vulcanized rubber route? Thanks in advance!!
Respectfully,
Steve H.
USA
smsla
Re: CastSolid resin use in kiln burn-out or in vulcanized mo
Postby smsla » Tue May 19, 2015 2:46 am
Also, has anyone incorporated sprues or gates into their prints? Or should I try melting wax sprues and gates on the CastSolid print prior to pouring the investment? I will eventually try this, so this is just a prelim question before I do, to inquire if it's been done before. Thanks!
Steve H.
USA
