http://www.ti.com/lit/ds/symlink/dlp3000.pdf
with one arduino due or another,
the question is ($$ x Work), because for 3d printer the frequence specifications of the change mirrors positions is very x 10³³³ (
one projector for full hd need 60hz, 3 colors * 8 bits (bad quality) and white color
I will need 766 * 60 = 45960 changes per second, in only one mirror, if it need be changed in all cicles,...
for one DLP 3D printer I don´t need it, if my cure time is arround 5seconds, I need change it only one time. 1920x1080 bits and "latch"...
I have time to make this operation, and get a coffee using one arduino due or mega i don´t know...
I will need one UV light, is very cheape, focal system lens, and lens to use the uv light...
I know it need much work, and I don´t know about the chip dmd dlp value,
but it is possible?
thannk you
