dev,
Checkout nanodlp installation guide for muve3d https://drive.google.com/file/d/0B8xCOd ... ZvVnM/view
If it does not help let me know exactly where in installation process it breaks.
						nanoDLP - Raspberry Pi DLP Host Software
				Kvirre
Re: nanoDLP - Raspberry Pi DLP Host Software
No reply on your email, so I will try here.
@Shahin
Is there a way to run nanoDLP in another Linux distro like Ubuntu etc?
(Tried to do it but failed)
This is what i did :
Downloaded through wget
Unpacked it to /home/
Ran the setup
Result : It still boots up in x (desktop), is this hardcoded to path only for rpi?
I need take use a "PC" for the displayPort (HDMI through rpi not possible).
@Shahin
Ran the setup
				kloknibor
- Joined: Wed Jun 24, 2015 5:20 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
for your other linuyx or windows distro's (and also raspberry pi btw) try Creation workshop host! you can find it here : https://github.com/area515/Creation-Workshop-Host
				Max
- Joined: Mon Jul 27, 2015 2:27 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
hi
Is there a feature in nanodlp to stop printing to let the PDMS breathe after some layers? Is it needed for the FEP also?
