hello everybody.i have got this piece of crap.It does not work((( Lsd does not work/i can see only backlight....
and no picture on lsd (raspbery version)
				Dr. Woo
- Joined: Mon Aug 31, 2015 5:39 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
@mandrea: Thanks for the info.
Have you tried a shorter cure time?
UV LED light source is standard/unmodded (2x10 Watts) or hacked/improved by any means?
That 32 mm wave you've mentioned, along which axis/direction? Mind to post a close-up/macroshot?
				malamen
- Joined: Sun Feb 12, 2017 10:21 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
why does motor cannot lift the platform.As if it is glued to the tank.and there is a strange noise from motor...and i can see thaat platform is rising only at one end-nere to the scrue...i have used the rezin that came with the printer....60 sec 2 layers and others 8 .but it cannot lift.....maybe thre is no teflon on the bottom of tank
				malamen
i understand this. but the object which i print is small.(should be small)).And i cannot understand  one thing.I get stl file in to workshop. save swg  file .And only after that i slice it. so how will it change the file i saved before?
				Dr. Woo
I can't guide you through Creation Workshop. You should start a new thread with a meaningful topic title in the  and ask the question there (this here is the Hardware Forum).
If your object is small, but the entire buildplate gets cured as shown in , it means that you are doing something wrong. Check your sliced images: I assume that the first layers (if not all) are all entirely white. But again: Post your question in the CW Forum!
				malamen
no, i can see the imagej n the screen.i even made smaller curing time...but it cannot lift up .Nd there is not only workshop.There is a soft for raspberry ...But it works if i save image and only after that i slice it....maybe i should plase workshop on disk C....I dont know were to write.The seller cannot help me.The only person is you and i hope you will help me.If it is possible send me your idias to my mail malamenr@mail.ru .Thaks alot!!!!!
				Dr. Woo
I'm sorry but I can't help you with your problems. To be honest, although I'm not a native english speaker either, I sometimes have a hard time following your descriptions. I recently accidentally came across a russian language 3d sla printing forum, where they discuss the KLD-1260 in detail. See here: http://roboforum.ru/forum107/topic17010.html
There’s also a russian/ukraine review of the KLD-1260, perhaps they have discussion on that site or you could talk to the author of the review: https://3dprinter.ua/kld-lcd1260-review/
