FTD (FunToDo) resins on LittleRP?
Re: FTD (FunToDo) resins on LittleRP?
Unfortunately I want to say that FunToDo just isn't real PDMS friendly and would hold up better with a teflon vat. I can get you an underplate which should improve your flexvat experience.
cew
I hope to try out these flexvats with underplates when they become available.
Are the prints failing part way (>5mm z axis) into the print?
I had a similar experience with divots on taller prints using the B9 black resin. This was solved by boosting the retraction rate to 300 and the lift height to 5mm with a couple of seconds settle time. It stopped parts of the print progressively adhering to the PDMS. This appeared to help flush the resin on the surface of the PDMS.
