				paul
- Joined: Sat Jan 07, 2017 10:27 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Check if your computer support 2k resolution (2560*1440)  if buy WITHOUT RASPBERRY PI
				LacoDeLoco
				epiX86
- Joined: Sat Feb 18, 2017 4:50 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
hey. I found a new printer that  exposure for 0.1mm is 3 sec, I that real?
				lgs777
- Joined: Sat Jan 14, 2017 10:33 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
I need help! I removed the resin tank and the part came out. I can not tell you how this part came out ...
The printer did not have a problem for a month but suddenly it happened.
I am very worried that I have a serious problem with my printer. How can I solve this problem? What does this part do?
				csader
- Joined: Fri Dec 30, 2016 12:25 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Dumb nanodlp question. I replaced the existing config.txt with what I found on the nanodlp forum. When I plug in the HDMI and USB and power up the raspberry pi, should I see anything on the printer LCD? Nothing happens for me. Even when I go into Projector calibration and click display on some of the calibration images, nothing happens.
Can someone who has this working well do me a favor and post some screenshots of as many tabs in nanodlp as you have the patience for?
				Deaner3D
- Joined: Sat Feb 11, 2017 6:18 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Hi all,
My machine came from FA-HA Store on Aliexpress. Seemed to be in good shape, just one scratch on the orange cover, and a small screw and nut loose in the housing. Removed that and everything looks fine.
Then I loaded Creation Workshop and ran into the first non-working issue.
Connected USB, HDMI(via computer with good graphics card), and power. Found connection through COM5, it seems to be ready. But when I connect and go to machine control none of the controls work. The motor won't turn, home, or anything. And I get some crazy characters fed back. Any suggestions?
*Update: I connected to the board via Pronterface, which is a host use for my other printers. I couldn't get the stepper to turn, but the endstop would report back triggered or not using M119.
**Update: Recompiled Arduino, uploaded, and can now move Z axis in Pronterface. Still no movement in CW.
***Update: Restarted CW, changed machine communication Port speed to 115200 and I can now move the Z axis in CW.
^one nice thing about recompiling/uploading the arduino sketch is I found where to change feedrate/homing and brought it down to 75mm/s feed and 50mm/min homing (from 150/150 stock)
