acer h6510bd serial commands - SOLVED
Scatterplot
Re: acer h6510bd serial commands - SOLVED
Use a terminal program to make sure your settings are correct and to make sure you get comms to the projector. If you can't get it to work in a terminal program then it's not a CW issue, it's a wiring or driver issue.
