it works !!! done last week-end:
									DVD reader is a SLA printer
- PomeroyB
Re: DVD reader is a SLA printer
Nice work! I'd love to see a video of it in action.
Very impressive! I see that they are using a CD as a first-surface mirror.
				FR3Dprint
tx u all.
the video can be seen on the FB page.
actually, the miror is a hdd and not a cd. optical miror are expensive and hard to find.... while a old hdd... there are tons around u ! the quality is fine and I see no difference with optical miror for printing. (I'd tested both).
				FR3Dprint
For the French readers or Google Translate users, you could see my website which was severely updated today, with infos on the control board and V2 printer pages.
Enjoy.
									Enjoy.
				FR3Dprint
Print of the day:
25mm high with 50µm / layer (max resolution limit of the DVD reader).
- PomeroyB
Very nice print! Looks good!
				CAP257RM
- Location: Roma (Italy) [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
I'am following this project and I have tested a dvd with a controller board toshiba TB6560 but I don't find the number of the steps for a right positioning of the plate. I have set the controller at half step, current 20%, voltage between 5v and 12v, steps between 9 and 9,15 (I need the right number). I use grbl firmware and  to move the plate Universal-G-Code-Sender.
						- cncbasher
dvd's steppers are pretty standard try  20 steps
dvd motor spec ( resonably standard )
pl15s020.pdf https://github.com/taksan/Arduino-Lab/b ... 15S020.pdf
the problem you will have is that the tb6560 , suit 1.8 deg steppers , where dvd steppers are 18 deg per step
so they probably will not be optimum .
you'll find full step is better for these drives , however i do not think the tb6560 goes to full step , i think the lowest is half step
so probably a basic L298 Circuit may be better , i dont know .
				CAP257RM
Thank, tommorrow morning I'll do some experiments.
