Board firmware please
				partsoven
- Joined: Thu Oct 16, 2014 4:02 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Can someone post the firmware for the LittleRP? My arduino seems to have taken a crap and I would like to try reflashing it.
				partsoven
Re: Board firmware please
Nevermind... connected to it via Arduino software and it spit out GRBL .80 and looks like I need to switch my baud inside of Creation Workshop to 9600.
				goopyplastic
9600 baud is the GRBL default, however newer versions of GRBL .9 etc. will use a higher baud rate.
				That_Guy
- Joined: Wed Feb 18, 2015 4:43 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Could you please post a link to the firmware
				goopyplastic
I ship with:
https://github.com/downloads/grbl/grbl/ ... z_9600.hex
.9 should work fine, but you will need to change / check the settings after uploading as the eeprom settings change.
