8 inch tablet and CW
3dprinter.org.ua
Postby 3dprinter.org.ua » Wed Aug 27, 2014 1:45 am
Good day. I use the tablet to control the printer. His performance is sufficient for slicing.
However, print several times hung in the process. But this is a small problem.
The problem of small government. Very hard to get on the tablet through the small buttons.
You intend to use skins? It would be great if there was a skin adapted to the touch interface.
So whether you are planning a multi-language support?
Can anyone translate it to other languages?
Re: 8 inch tablet and CW
Postby PacManFan » Wed Aug 27, 2014 11:07 am
Translating into other languages is something that I am currently looking into. A few days ago, I order a Win8.1 tablet for my LittleRP machine. I plan on mounting it directly onto the machine. I will try to make the software more tablet -friendly.
3dprinter.org.ua
Postby 3dprinter.org.ua » Thu Sep 04, 2014 8:33 am
Postby PacManFan » Thu Sep 04, 2014 11:04 am
Postby hp_ » Mon Sep 08, 2014 11:00 am
Hi Pacmanfan,
i'm buying a Acer Iconia W4-820 32GB Zilver will report back how it goes with CW
3dprinter.org.ua
Postby 3dprinter.org.ua » Tue Sep 16, 2014 7:36 am
Postby PacManFan » Tue Sep 16, 2014 12:15 pm
Still working on the graphic tweaks now. It works as-is, but some of the buttons may be a little tough to press.
3dprinter.org.ua
Postby 3dprinter.org.ua » Mon Sep 29, 2014 4:54 pm
Good day.
I want to prepare a file on the PC and then copy it to the tablet. the problem is that on the tablet when opening scene file there are no objects on the platform. Maybe I'm sharing something wrong. Help me, please.
There is a good idea. Need to implement a quick opportunity to send a file to print in the case of construction when the printer is connected to a weak PC. Maybe you should make the system identification slave / master. Recognition do UDP broadcast packets. In CW program can be selected that the printer is connected to your PC. All other PCs running programs CW will know to what exactly the printer connected to the projector. Then all the other PCs on the network will be able to either save the file prepared for SD, or the touch of a button to send the file to the printer prepared and run printing. What do you say?
Postby PacManFan » Mon Sep 29, 2014 8:52 pm
3dprinter.org.ua
Postby 3dprinter.org.ua » Tue Sep 30, 2014 11:37 am
I would be willing to buy the paid version of the software with features.
Sale of the paid version of the program would be able to partially solve the problem of funding.
