Would anyone be interested in buying the extrusions needed for the DLP build that Tristram Budel posted on Instructables off of me? I was going to build one, but have since decided to go with a different design.
It can either be assembled as it is now OR I can take it apart (assembled will cost more to ship).
Asking $75 (plus shipping of course) for it. Just the extrusions and brackets for the structure. No other hardware included.
https://www.dropbox.com/s/et36v5spy84k5 ... .28.15.jpg
									Extrusions for Tristram's Instructable DLP
				AndersonTa
@AndersonHTa
				Finhead
Re: Extrusions for Tristram's Instructable DLP
Anderson, how long are the bottom braces? I might be interested if it's able to be converted to a none mirror configuration but that would depend on the bottom extrusion length.
Clinton
Clinton
				AndersonTa
Clinton,
The bottom extrusions are 450mm long.
@AndersonHTa
				MichaelD33
- Joined: Mon Aug 18, 2014 12:02 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Just a quick question, where did you get them? I just want to see if I can put them to use, but it depends on some things.
				AndersonTa
I got them from Misumi. They are the exact same specs as Tristam listed.
What else do you need to know?
@AndersonHTa
