Alright, I'm going to have to put in more debugging and get you another test build tomorrow. It looks like it's finding the interfaces correctly, but not connecting for some reason. Did you uninstall the previous driver and install the drivers I provided? What is your system configuration - Win 7 -8? I don't have Linux support through mono quite yet.
- Location: Novi, MI [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Back in business! I wiped out all the old driver files again and reinstalled yours. Looks like one didn't update or overwrite. Mirrors are moving now! Now working on why the laser isn't turning on
Thanks!!
Which laser output are you using? You should connect to the 'c' output. This is something that I haven't tested yet, I haven't got a ttl output connected on my setup.
Looks like the 'c' output has voltage along with 'a' and 'b'. It's shutting the laser off, but will not activate it. Tried it on all connections with the laser turning off. Once I remove the connections the laser turns on.
