New version (0.1.016) has been uploaded. This version has some bug fixes regarding Grbl 0.8a and 1.1f firmwares.
Now MonoWare has some integrated functions/features for preparing models and controlling your printers!
- Intuitive arrangement of UI menus. Manuals will be updated soon.
- Import STL/OBJ files and arrange them.
- Generate grid type / manual supports. Fine tune your support positions and point radii.
- Fast hard accelerated slicing (~ 10 slices per a second for 1920x1080 resolution) and real-time preview.
- Connect your DIY printers based on UNO+CNC shield or MEGA+RAMPS1.4
    (I recommend Grbl 1.1f for UNO or MARLIN 1.0 MUVE patched for MEGA)
- Make better projection via barrel distortion correction, light intensity correction, and anti-aliasing
- Balance the print quality and time via variable vertical steps [full version only, beta]
- Upload your firmware inside the MonoWare
If you have not got the MonoWare Lite yet, you can get a free download from https://www.monoprinter.com
Your report on any bugs or issues would be appreciated. Please send me an email at info@monoprinter.com.
Thanks.
Yun
				danthehuman
- Joined: Sat Jun 17, 2017 2:21 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Giving ver .016 a try on Win 7 64 Bit
				cooly
Please report any issues and problems here so that I can fix those on next release.
I also found a bug during recipe file loading, so please keep your printing condition or copy recipe.txt file to another location.
Yun
Yun
				GGresham
- Joined: Sat Sep 09, 2017 11:29 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Great, thanks Yun.  I'll give it a try on the DIY printer when I finish the current build.  It would be so cool to get that clunker working.
G
						G
				cooly
I just posted a blog article about grayscale mask generation using MonoWare. Please come and see how to create a mask image to make more even light intensity across the build area.
https://www.monoprinter.com/blogs/monow ... h-monoware
				cooly
New version is released (0.1.021).
New features include X-ray view, multiple loading of scene files, and CWS file format export (Full version only). Rendering has been also changed to see models easily.
You can download the Lite version for free at https://www.monoprinter.com
