LittleRP Projector spacers
				crazymonkeyni
- Joined: Fri May 26, 2017 3:51 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
When I first ordered my printer I had requested they ship the parts to mount an Acer P1500, when I received the kit I put it in storage since I didn't yet have the projector but planned on purchasing it. Upon opening the box for my printer I discovered the bag with the projector kit was missing. I don't have the screws or spacers for the mounting of my projector so now I'm trying to find out what the parts are that I need to purchase. What size are the spacers? Any help would be much appreciated!
				goopyplastic
Re: LittleRP Projector spacers
The P1500's are generally M4 hardware. So (3) m4x20mm with about a 5mm stack of m4 washers should do it. As you go further back into the alternative mounting holes you will need to add about 2.5mm per extra hole you go back (there are 4 holes in a line).
				crazymonkeyni
Thank you!
