LCD SLA 3D Printer
ionel.ciobanuc
LCD SLA 3D Printer
Postby ionel.ciobanuc » Thu Dec 01, 2016 3:04 pm
My printer with resin and LCD screen.
Raspberry PI 3 - nanoDlp - Movement GPIOs - Drivers a4988
LCD 5 inch 800x480 not BEF
x/y 0.135mm
Layer Thickness = 0.05mm
Cure Time = 10 seconds
Lift 2mm
Daylight Resins
matrix LED 11W
These are my results:
I have a lot of work.
Re: LCD SLA 3D Printer
Postby hp_ » Thu Dec 01, 2016 3:14 pm
hi ionel.ciobanuc,
Welcome to the forum, I've been watching your lcd printer, very impressive and great work..
allot of work! :)
dragokirov
Postby dragokirov » Wed Dec 14, 2016 6:46 am
The first test after the rebuild of my LCD 3D printer
sodium
Postby sodium » Wed Dec 14, 2016 2:51 pm
dragokirov
Postby dragokirov » Fri Dec 16, 2016 3:05 am
I sold the rights to the membrane of another company
For the printer I use 1280x800 7 inches LCD and four kinds of LEDs with different power and different wavelength. I'm still not sure if this is the right combination because there are a problems if I use 100% power. The resin is cured the entire of the bottom.
Regards
Kvirre
Postby Kvirre » Fri Dec 16, 2016 5:23 am
ionel.ciobanuc
Postby ionel.ciobanuc » Wed Dec 21, 2016 3:19 am
My VAT
Matrix LED is in testing. I have trouble angle.
I used:
I'm working on one with
How connected "display iPad4" to raspberry?
dandumit
Postby dandumit » Wed Jan 18, 2017 5:11 am
Nice work ! and nice results !
Could you please tell from where did you bought the film ?
(I am also from Ro)
Kind regards,
Daniel
Kvirre
Postby Kvirre » Fri Mar 03, 2017 8:24 am
ionel.ciobanuc
Postby ionel.ciobanuc » Wed Apr 26, 2017 9:31 am
It did not work with the original background light. Or I did not have patience.
