SimplySla by Goldi80
Let' see your handiwork!
goldi80
Postby goldi80 » Wed Nov 23, 2016 8:08 pm
Simply Sla by Goldi80 use ramps 3 stepper and Repetier
the print are very good next is to make case for it
20w uv laser 0.05 dot
speed 200mm/s i will go 400 wen i make better shell
it works and is good cheap
For one model 25u i have 50min z lift and 1.20h print total 2.3h per print i like it.
Try any dlp and sla resin all work the same.
https://youtu.be/oASrp-KSkAk
goldi80
Re: SimplySla by Goldi80
Postby goldi80 » Thu Nov 24, 2016 6:06 am
viewtopic.php?f=13&t=5019
Whit senertec resin
goldi80
Postby goldi80 » Tue Dec 06, 2016 5:37 am
Postby hp_ » Tue Dec 06, 2016 12:51 pm
Hi goldi80,
Looking great!
goopyplastic
Postby goopyplastic » Tue Dec 06, 2016 12:59 pm
Really great work, let me know if I can help in any way.
Mr. LittleRP
goldi80
Postby goldi80 » Tue Dec 06, 2016 5:58 pm
My case or shell is not screw i put some ca glue to hold it really dont i order new plexi it will be screw all Pieces in 10mm plate
this is no good and belt is lose and not event is prototype.
i do not have 32t pulley now is slow 2x. order for banngood it will take forever to come
i need to put 32t now it have 16t 200steps need to be 100steps 1/16 then is real fast and the arduino breath no calculation the weight is 22g laser and holder -
the problem is slicer dot or line from photo to gcode or .slc if you dont complicate gcode i get good small size txt and print. laser is hard to move proper
Regards
