i write my own software for 3D DLP Printer: http://morellirobotics.com/3d-dlp-print ... -software/
Can you download and try? Than give me some feedback?
Morelli Robotics
Software Art3Dlp
- Joined: Mon Jan 18, 2016 3:11 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Re: Software Art3Dlp
Hi Morelli Robotics,
your slicer is very fast, I'm impressed.
However, there is no way to export the slices and there is no gcode, so I can't use it to actually print anything.
If you can export to PNG files, we could test it.
Good luck!
Good luck!
How do i setup my own machine?
DIY with Acer Beamer. So i would need configurable print size and adjustable printer height, at least.
