Hi, I wanted to design a 3D printer frame which could host hardware for SLA or SLS manufacturing process, could be completely enclosed if necessary and would allow easy switch between bottom-up and top-down. This is the result I constructed last year:
Top section of the frame was equiped with Z-axis linear guides and ball spindles on both left and tight side. It is currently driven by single timing belt, however I am considering to drive both sides with dedicated steppers and perform peel action by independent movement of Z-right and Z-left.
In the bottom section there is Lasershark-based "laser projector" mounted on an extrusion profile:
Z-axis electronics is missing - I have Megatronics v3 prepared on my table.
Build platform is missing as well - it will be mounted on the extrusion connected to linear carriages.
I only have small VAT from Pryntech kit available at the moment: http://pryntech.com/?product=optically- ... crylic-vat
I will build larger VAT later.
What kind of VAT construcion and peeling mechanism would you recommend?
SLA printer build
danielm
Re: SLA printer build
An update after a long time - this is how the frame looks right now. In the bottom part you can see the projector with my own electronics driving the galvos and stepper.
And this is one of first test objects - not very clean, but it works:
Next steps are experiments with VAT using Drago's sheet and improvements on the SW side.
dragokirov
HI Daniel,
Good job! I have a question. Why you do not use a mirror to adjust the distortion and to save a space? I think it's better. I use an adjustable mirror and two sliders.
Drago
Drago
danielm
Hi Drago, thank you.
Could you please elaborate more on how the mirror can be used to adjust distortion?
D.
D.
dragokirov
The adjustable mirror allows to tune the laser in correct angle of projection much easier. In this case It is not necessary to move and adjust the box or the galvo. And something else. You can put plano-convex lens on the bottom of your VAT for better accuracy.
Regards
Drago
Regards
Drago
jose
- Joined: Mon Jan 11, 2016 1:18 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Drago hello I am new to this and I'm starting with great enthusiasm the project of a 3d printer sla and I'm picking up the electronic and software needed for operation. I have seen on aliexpress and kit laser 200mw 405nm Blue Violet laser diode module 12 V Cc Ttl stage lighting, and Faster Shipping: laser 30 Kpps Galvo galvanometer based (including display card) is not whether ent serve you reference but it can be good the set for my future diy printerhttp://es.aliexpress.com/item/Ho ... 264.bXTEme
