Getting prints to stick to build plate
kakapoopie
Postby kakapoopie » Mon Jun 22, 2015 10:34 pm
Hi all, I'm having trouble getting large surface area prints to adhere to the build plate. (peeling up around the corners) Thinking of sanding down my steel build plate to get better grip. Anyone have suggestions on how to get good ahesion?
Best,
Vaughan
Xoxu
Re: Getting prints to stick to build plate
Postby Xoxu » Tue Jun 23, 2015 11:44 am
Hi
I have see this guy have make many test on his website so maybe you can found your happiness ;)
Taher1360
Postby Taher1360 » Tue Jun 23, 2015 12:43 pm
Hi Man
This problem can be caused by low ratio adherence between the build plate and the VAT.
for best printing this ratio will be more than 100.So you should use a metal with high adherence like Aluminum with a good polish surface as a build plate and use Teflon VAT like with super low adherence.
kakapoopie
Postby kakapoopie » Tue Jun 23, 2015 3:23 pm
kakapoopie
Postby kakapoopie » Tue Jun 23, 2015 3:24 pm
Taher1360
Postby Taher1360 » Tue Jun 23, 2015 5:15 pm
newraper1963
Postby newraper1963 » Wed Jun 24, 2015 10:26 am
Vaughan, my printer is basically the same as yours. I use a piece of plain stock aluminum 1/8th inch thick. 1/8th inch holes were drilled 1/4 inch on center. This left me with 1/8th inch spacing between holes. I have used Fun To Do IB and CB successfully for months.
