must see ifno needed
transformer
Postby transformer » Thu Jun 18, 2015 10:14 am
ok so here the dealio :?: build my top down and all working with a small odd problem..ok I put the projector on top and made a cube 10mm x 10mm x 10mm moved the build plate till cube from projector was aproxx 10 x 10 mm so did a test print and.......sweet came out 10 x 10 x 15.7 ...so when online used the http://prusaprinters.org/calculator/ and got..2560.00 Click to Share! 1.25 1.8° 1/16th 1 : 1 so I put 2560 in sprinter instead of the 3200 that was there...did another print and cool 10 x 10 x14.2 ok now getting lost?....so I marked the 8mm smooth shaft on my z axis and in cw moved it down 10mm checked at it was 13.36 not the 10mm..........I have no CLUE HERE :( heres my set up ramps 1.4 arduino 2560 nema 17 8mm lead screw from purisa i3......
transformer
Re: must see ifno needed
Postby transformer » Thu Jun 18, 2015 10:21 am
ohhh also cw can not set my projector to 1920 x1080 ....only shows as 1280 x 720 its the acer h6510bd
Postby PacManFan » Thu Jun 18, 2015 1:16 pm
transformer
Postby transformer » Thu Jun 18, 2015 3:08 pm
well I think I got it .... had to trick sprinter into believing I was using 5/16 and not 8 mm and bam .4 off not to bad 10.41mm
Postby PacManFan » Thu Jun 18, 2015 10:06 pm
transformer
Postby transformer » Fri Jun 19, 2015 7:12 am
that's what I used everything working great..... just have to find the happy medium on the first layer a few times now I over cooked the first layer at 6000 ...but cure time for every other layer is 2000
