Here is something I printed last night. Took about 5 hours to print. Using a new formulation from MakerJuice. It had some strange holes develop on one side, not sure why they didn't appear on the other side or anywhere else because the walls are the same thickness throughout. The walls are very thin, probably too thin for this scale but turned out pretty well.
I did over sample the slices about 3.5x then scaled back down in Photoshop. There were 1389 slices total. Each layer exposed for 9.5 seconds - total layer time 13.5 seconds.
Iron Man MK-42 helmet - 1/2 scale
Re: Iron Man MK-42 helmet - 1/2 scale
It actually looks way better than I thought it did. The side that turned out is pretty nice, forgot to ask what resolution (Z) did you print at?
hi watsonstudios,
very nice print
what kind of dimension is it?
it looks like 10cmx10cm
i've got my build plate ready today, 90mmx76mm
i'd love to give it a try
very nice print
Hi Watsonstudios,
That is a beautiful print! I'm very interested to test using over-sampled images. What process are you using?
Thanks,
Craig
Thanks,
Craig
No t to step on an toes but Jon has the process he uses listed in his build thread about 3/4 of the way down first page.
Clinton
Clinton
