The 3d print is 86mm X 70mm X 19mm without the supports. The layers you see are 0.1mm thick.
technical details can be found at http://projectsinterestsandetcetera.com/
									photos of a 3d print made on my updated printer
				watsonstudios
Re: photos of a 3d print made on my updated printer
Clean print!  I'd be curious to see the underside once the supports are removed.  Usually the underside of prints (the sides facing the build plate) tend to get a little bumpy from the resin not curing at consistent depths.  A problem I hope can be solved with better resins in the future.
Thanks for sharing!
						Thanks for sharing!
Hi HTL,
I read your blog with much interest!
very nice blog, and nice print,
the light source in you projector is not UV is it?
Cheers,
Cheers,
No, the projector light source is not uv. The projector is a totally unmodified (with the exception of a +4 closeup lens for close focusing) toshiba T95.
So your curing the resin with the color wheel intact and fully untouched projector (besides the lenses). Thought that wouldn't work properly?
						- 258cj7
I'm also using a projector with the color wheel intact. The only mod was to the focus ring. Cure time for MakerJuice SubG+ is 5.5 seconds.
Mitsubishi XD430U 1024x768 native 230w UHP bulb
