Large 7.5 Solid Print
Magnitude
- Joined: Fri Aug 29, 2014 12:30 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Learned a ton working with this model in its solid form. Made with G+ red at .12mm z and 100xy.
kakapoopie
Re: Large 7.5 Solid Print
nice! Pretty thick Z...also how do you combat warpage on large solid parts? Usually starts curling up for me.
adambx
could zou show us the underside? what kind of release system do you use?
Magnitude
@kakapoopie Yes curling is a b*** with these little machine and large pieces. I am working on a little trick to combat it. I will let you know when I get a little farther with it.
Magnitude
@adambx The underside is dotted from my build plate holes. This is a top down setup so no release.
kakapoopie
I'm getting the dimples on the underside too...is there a way to get around this with top down?
Magnitude
Support / standouts if your using a perforated build plate.
