LCD SLA 3D Printer 50W LED
3DJLed
Postby 3DJLed » Mon Aug 28, 2017 11:36 am
Hello,
I had an 4 inch screen and a Raspberry Pi of which I did not know what to do then I made one LCD SLA 3D Printer !
I was inspired a lot by the work of Ionel Ciobanuc ;-)
Description :
4 inch LCD Screen
Raspberry Pi 3
Arduino Mega & RAMPS 1.4
ProjectLayer
50 W 405nm LED
Parameters :
- Layer Thickness = 0.1mm
- Cure Time = 12 seconds
- Lift 20mm
- FunToDo Snow White Resin
The principle is so simple but the development, a little less!
Thank you all !!!
Jled.
3rv3r
Re: LCD SLA 3D Printer 50W LED
Postby 3rv3r » Thu Nov 16, 2017 5:02 am
How are you switching the 50W leds on/off ?
3DJLed
Postby 3DJLed » Wed Nov 22, 2017 6:08 am
Hello,
I use a relay connected to fan output and I command light on/off with gcode command m106 et m107.
JulioPu
Postby JulioPu » Sun Dec 17, 2017 9:43 am
Cool dragon!
