My Dlp printer
258cj7
My Dlp printer
Postby 258cj7 » Mon Jan 06, 2014 10:36 pm
It was a long time in the making but I finally finished my printer. I set out to build a relatively low budget machine partly to prove you didn't need to spend a fortune on ball screws and precision linear stages but also because I had limited resources. It's not pretty, but it is functional and seems to print well. Currently it is controlled by Mach3 but I would like to make it more user friendly and interface it with the Creation Workshop software.
I have a blog of it here
http://johns3dp.blogspot.com/
Re: My Dlp printer
Postby PacManFan » Mon Jan 06, 2014 11:14 pm
Excellent build and blog! I'm really impressed with your results. I need to try out the black resin myself.
258cj7
Re: My Dlp printer
Postby 258cj7 » Tue Jan 07, 2014 12:11 am
Thanks. I'm actually really happy with how well it prints considering how low budget it is.
How about that Z axis? Just some angle iron and roller skate bearings.
seasicksinbad
Re: My Dlp printer
Postby seasicksinbad » Tue Jan 07, 2014 1:11 am
Congratulations on your success!!
johnrpm
Re: My Dlp printer
Postby johnrpm » Tue Jan 07, 2014 4:02 am
I like it, mine is also a long time in the making, but
seeing yours gives me some encouragement.
I hope you will join this little community of ours.
James
Re: My Dlp printer
Postby James » Tue Jan 07, 2014 11:11 pm
I recognize some of your images from the yahoo forum. Good to see you here and great work! :)
I love your Z axis! I'm amazed by the high resolution results you're getting from that!
258cj7
Re: My Dlp printer
Postby 258cj7 » Tue Jan 07, 2014 11:35 pm
James, Thanks. Yea, the thing is... It doesn't have to be expensive (or look good), it just has to be solid. Those angle irons don't flex at all and I've got the bearings preloaded so there is no slop. I did spring for a nice ACME screw but made my own leadnut from Delrin. It's not anti-backlash but it hasn't been used enough to wear much. I'm hoping that when it starts to wear, gravity will take care of the backlash.
