As You surely noticed, I asked You for a few things to rectify my knowledge. Now after collecting pieces, knowledge and ideas I can fully start fight with my project. I am M.Sc.Eng so I think the mechanical issues would not be a big problem, unlike the electronic issues. I know the G-code well and I can understand the algorithms but I have never written any code by myself (only visual basic at university).
So, I decide to build the small desktop printer using a mirror system and the B9 tilt idea with moving drawer to avoid fighting with code and using only 2 motors - stepper and servo (but the servo I have has only 120 degrees angle, so maybe a will change it for stepper or 360 one). Also, my drawer will be mounted on typical 8/10 mm roller, not on POM or other plastic material.
The main goal is to build the printer ready to print with the smallest layer as we can to made a soft surfaces without layering stairs - this is the most important thing for me, because my Form1+ is definitely not good enough.
By the next few days I want to work with firmware to make it useful. I already downloaded and tested the mUVe 1 software but... It doesn't work as I would like. Can anyway help me with coding or would be able to tell me what should I do? I updated my Arduino MEGA and when I try to print with the standard mUVe 100 layering the stepper is spinning but...
I would like to push stepper to go for "home" position first, before printing. Home position would be limited by the mechanical endstop called 1, then the print should start. At the moment my stepper is spinning up and down with every layer but not go anywhere before printing
Also, my servo is getting crazy when I wire it to the 4th line (4th from the left) and it is under control. If anyone had the same issue would be nice to know what should I do. Leave the servo or just change something.
I would be very grateful for any kind of help with it. As I wrote, I am not an programmer and If there is already existing firmware working with my thinking way would be nice to not ram through an open door!
Here are the pictures of my project (not finished but You can see main ideas) + the whole things I already completed.
Kind Regards,
Arco
