Hi sszer,
it looks like your moving part will be the Vat is this correct?
3D DLP printer greatly improved print quality with flex fep
Re: 3D DLP printer in concept stage
That looks interesting as HP said is the Vat the part that will move? If so is it to use the weight of the vat/resin to help with the peel.
Looks like it's coming along nicely.
looks like the projector moves with the vat, to maintain focus.???
- Joined: Tue Jan 28, 2014 5:17 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
The vat does not move. het object moves.
The linear guide I've made is a bit different from what is common. That causes the confusion i guess.
I'll post a clarifing picture when my stepper driver is working (again, i toasted the previous chip, ooops).
If the vat would move, the mass would have no effect on the release. Since the mass would be just a force acting on the object, The same as would be achieved by the stepper motor (it also acts a force, so no difference).
- 258cj7
Interesting Z axis design. Does the slide maintain stability at full extension? (When the two pairs of rollers are close to each other). It's probobly not an issue unless you plan on printing really tall things.
You're answering your own question.
Yes, the slider wil become less stable (not unstable!) when the rollers are close together, but that can pose a problem when the object reaches a hight of approx 20 cm, something i'm not planning to use often.
I used this design to get a linear guide that i could make myself and is cheap.
Greetings and Congratulation, Dear Szzar,
Thanks for posting, sharp photographs of your 3D printer. Will you please post some photos of your printers electronic boards and details on the controller's connection.
Best Regards
Sid Rana
Best Regards
Sid Rana
The electronics, is just an arduino with a stepper driver, pins for a servo, motor and end-switches. Nothing too complicated (although the switches are hooked up to a comparer circuit, something that is not strictly needed).
Hello Dear Szzer,
Thanks for your time, and reply. Are you using CW software, and how about the firmware.
Sincere Regards
szrana@mac.com
Sincere Regards
szrana@mac.com
