I will be following closely all threads about Top-Down in this forum. I think this is the best way to go, at least for people who only want to print small stuffs like myself.
@PacManFan: Thanks for the advice and encouragement you gave me. That means a lot!!
But now that I'm convinced that building my printer will be "fairly easy", I'd like it to be a standalone unit (using a Raspberry pi), independent of a PC once the slicing task has been done. Could you advice me more on this? What should I do to get there?
						DLP Top Down IT LIVES!
				anthony.julu
- Joined: Fri Aug 29, 2014 12:19 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
				kakapoopie
Re: DLP Top Down IT LIVES!
Spent last week tweaking and testing some more.. One feature that I think could help cut down print time alot would be an adaptive z reset height (go down more on layers with bigger surface area for proper resin coverage, less on layers with small surface areas ie support columns)
Test prints:
						Test prints:
				Magnitude
- Joined: Fri Aug 29, 2014 12:30 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
@kakapoopie This is def needed large surface area slices are a PITA.  If there was a calculation made on the largest surface area prior to printing a layer. A simple algo could be popped in that adjust depth of dip and potential a delay time if needed.
I am going to be installing a heater in the my vat usings ramps outputs that I hope will get the resin to move a little faster. I do not believe that will be a fix but a step in the right direction maybe.
				kakapoopie
Guys what's the advantage of a wiper?  So far it seems like the resin self leveling is working fine.
@magnitude...yea especially with a large build area like you've got that could make a huuuge time difference.
also, with heated less viscous resin are you worried about increasing wait time for ripples
				Magnitude
@Bobbitay I am avoiding a wiper for the time being.  To be honest I still am unsure what it does. Is it just to speed up large surface coverage?
My cure times are 9 seconds right now so the ripples tend to level as it cures.
- bobbitay
- Location: Boise, Idaho [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
I also am avoiding a wiper for now, but I always assumed it was a way to quickly get an even layer quicker than simple settling time and if you do have a meniscus effect or bubbles it could help diminish those, as well.
				Magnitude
@bobbitay its probably only a matter of time then before I add one especially if it can speed up builds.  I will work with the software for now and report back results.
				kakapoopie
 about 12" travel
  about 12" travel
