LCD SLA 3D Printer
ionel.ciobanuc
LCD SLA 3D Printer
Postby ionel.ciobanuc » Thu Dec 01, 2016 3:04 pm
My printer with resin and LCD screen.
Raspberry PI 3 - nanoDlp - Movement GPIOs - Drivers a4988
LCD 5 inch 800x480 not BEF
x/y 0.135mm
Layer Thickness = 0.05mm
Cure Time = 10 seconds
Lift 2mm
Daylight Resins
matrix LED 11W
These are my results:
I have a lot of work.
https://www.youtube.com/watch?v=uhGwFF9nYvwImage
Re: LCD SLA 3D Printer
Postby hp_ » Thu Dec 01, 2016 3:14 pm
hi ionel.ciobanuc,
Welcome to the forum, I've been watching your lcd printer, very impressive and great work..
allot of work! :)
dragokirov
Postby dragokirov » Wed Dec 14, 2016 6:46 am
The first test after the rebuild of my LCD 3D printer
https://www.youtube.com/watch?v=jp0008fSSF4&feature=youtu.be
sodium
Postby sodium » Wed Dec 14, 2016 2:51 pm
dragokirov wrote:The first test after the rebuild of my LCD 3D printer
hi drago,
what happened with the film you were developing?
also, your curing time is subtantialy lower compared to the new chinese printer sold in aliexpress. i suppose you are using ftd resin, more than anything to compare results with hp. can you post lcd panel and led details?
dragokirov
Postby dragokirov » Fri Dec 16, 2016 3:05 am
I sold the rights to the membrane of another company
For the printer I use 1280x800 7 inches LCD and four kinds of LEDs with different power and different wavelength. I'm still not sure if this is the right combination because there are a problems if I use 100% power. The resin is cured the entire of the bottom.
Regards
Kvirre
Postby Kvirre » Fri Dec 16, 2016 5:23 am
ionel.ciobanuc wrote:My printer with resin and LCD screen.
x/y 0.135mm
Lift 2mm
Daylight Resins
matrix LED 11W
Very nice nice build!
I'm all into Daylight printers (http://www.kvistholm.se/Daylight-Resin-Printer)
Would you mind sharing the VAT-construction (STL / .step)?
And where did you get the LED Matrix, if ebay, could you provide a link?
ionel.ciobanuc
Postby ionel.ciobanuc » Wed Dec 21, 2016 3:19 am
My VAT http://www.thingiverse.com/thing:1937090
Matrix LED is in testing. I have trouble angle.
I used: https://www.youtube.com/watch?v=2yN3dgI24cI
I'm working on one with https://www.youtube.com/watch?v=2yN3dgI24cI
How connected "display iPad4" to raspberry?
dandumit
Postby dandumit » Wed Jan 18, 2017 5:11 am
Nice work ! and nice results !
Could you please tell from where did you bought the film ?
(I am also from Ro)
Kind regards,
Daniel
Kvirre
Postby Kvirre » Fri Mar 03, 2017 8:24 am
ionel.ciobanuc wrote:My VAT http://www.thingiverse.com/thing:1937090
How long was the curing time for 1 layer using the original backlight?
ionel.ciobanuc
Postby ionel.ciobanuc » Wed Apr 26, 2017 9:31 am
It did not work with the original background light. Or I did not have patience.
