Hi guys im starting a dlp buld, this is my first attempt to build a 3d printer with(kinda) my design. So my plan is to use an old flashforge plywood box for my base, this is how far i have gotten into the design and i don't know if i am exactly on the right track.
Do i install linear glides on the back plate( as pictured)
Or do i keep it FDM printer style (b9 creator) and do it with linear bearrings and smooth rods? A combination?
Thx for the feedback -sorry for my bad english
Starting a DLP build
- Joined: Wed Jun 10, 2015 9:34 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Re: Starting a DLP build
Okay then, ill give it a try without any feedback, i guess trial and error will have to do
Hi, i appreciate that, i really needed someone to boost my confidence before i start.... Btw i am using a 1204 ballscrew, will a regular nema 17 be ok or do i need to go with a higher torque variety... ? Thank you
The guys over at the 3d printer google groups told me that i shouldn't add a ballscrew mount on the other end of it, thay say it would add wobble, any thoughts?
The z axis extrusions are going to be connected directly to the linear rails going through the wood
I am planning to get the back panel laser cut because otherwise i will have to drill the holes for the linear guide rails by hand and i'm afraid i wont be able to do that as precise as the laser will
Best case scenario....it comes out looking like this
Off to the workshop! Wish me luck
- miribota
- Joined: Fri Aug 22, 2014 3:24 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Looks good, be sure to post build photos.
Do you have a plan for your vat yet?
