Nica 3d DLP Printer
- Location: Pretoria South Africa [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Nica 3d DLP Printer
Hi. My name is Adolph Smith and i am from South Africa . I have design a 3d DLP Printer - Nica 3d Printer : http://www.thingiverse.com/thing:492211. I am 3d designer and want to built my own 3DDLP Printer. I hope you guys except me here and help me .
Re: Nica 3d DLP Printer
At this moment my printer print inside my reservoir. Is it because i have a glass plate under and a reservoir. Is it possible that it reflects on top to bottom. Any help please. O and the attachment i moved the scope that is why it moved but the problem is the print inside reservoir and not to printbed.
anodizing your buildplate might help with reduction of your problem of reflection
Thank you
I have even paint the printed for it not to reflect the light back and same story. The part print in the reservoir. Not on bed ??
- Joined: Wed Dec 18, 2013 11:34 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Why are you trying bottom up?
Try top down with a wiper.
- Joined: Wed Jun 10, 2015 3:45 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
anodizing would definitely solve the issue, but have you tried painting it black ? or perhaps scratching the surface with sand paper ?
