This printer looks great . is there anyone who have this printer already ?
https://www.aliexpress.com/item/2017-40 ... 02888.html
YHD-102 LCD Printer
- Joined: Mon Jul 10, 2017 9:31 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Re: YHD-102 LCD Printer
I've ordered one but looks like they're back ordered till early Aug. I'm new to this forum and resin printers but have a couple years experience with Printrbot fdm. Not exactly sure what I'm getting myself into by ordering one of these proniks kld-lcd printers and not a lcd printer with a larger community instead. Although it's kinda hard to tell if any lcd printer has much of a community yet.
Also hoping i don't regret ordering the new version! It will be exciting and a learning experience for sure lol!
- Joined: Mon Jan 02, 2017 6:43 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Received mine. I also own the 1st generation YHD-101 so I can compare.
The printer looks more professional with a bigger Z print size but:
> it's no more open source, you need to use their slicer.
> the wifi remote is not fonctional: you need to put your files on a SD card, and then plug it on the printer thanks to the USB port.
> and last but not least, until now I have been unable to print: the printer don't recognise my print files... so I try to see with James what is the problem.
Ok folks, once again James has been helpfull and my printer works!
So if you have questions about this printer, here I am
