Proniks KLD-LCD1260 / YHD-101: Improvements needed and technical support
- Joined: Sun Feb 12, 2017 10:21 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Re: Proniks KLD-LCD1260 / YHD-101: Improvement & feature wish list
i think the problem is the axis Z .
- Joined: Wed Mar 29, 2017 5:47 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Re: Proniks KLD-LCD1260 / YHD-101: Improvements needed and technical support
Hi guys
I am new on this forum. It is my first 3d printer. I was buy it on aliexpres from James (china) and I have problem with this printer.. The screw moves only up not down (movement up is fluent). When i give command go to home position it moves up.. I was reinstal software on rapsbery and on arduino too nothing is changed.. can it bee software or hardware problem?
Can somebody help me?
sorry for my english..
Karel
Karel
problem fixed
it was broken cable from end stop not visible damaged but broken i was changed cable and printer works.. 4 days of testing
- Joined: Sat Mar 25, 2017 10:51 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Concerning improvements...
Provide to the seller the working printers!!!
to start it would be good.
