Hi everyone! Greetings from Argentina! Thank you for all this usefull information!
I have just pull the trigger, and order one of this little printers for me!
I want to ask about the resins, there are some limitations and extra costs in shipings to my country, so I I'm thinking of buying some variety packs of resins from MakerJuice.
I've seen some nice prints with the G+, and with the WAXCAST,but can't find anything with the SF resins. Does anyone have experience with them?
Cheers!
- Joined: Wed Apr 26, 2017 8:39 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
- Joined: Tue Apr 25, 2017 11:37 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Thank You for your answer Mandrea!
- Joined: Sun Dec 04, 2016 5:48 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
< edit >
Totally misunderstood after reading too fast
( hence edit )
If you printed that mesh object without a solid base layer it's never going to stick.
All my objects need about 60 sec for first four layers and that layer is at least 10x10mm...then 9sec per layer.
That's senertek cast resin and a 20w led.
Cheers
//O.
( hence edit )
Cheers
//O.
Hi @all
i try to print since days without any good results. The first 3 layers stick to the printbed everything else sticks to the FEP.
I use the resin from china (it was shipped with the printer) https://www.aliexpress.com/item/resin-f ... .11.R6w4Ge
Slice Height (mm): 0.05
Exposure Time (ms): 15000
Number Of First Layers: 3
Exposure Time For First Layers (ms): 120000
Z Lift Distance (mm): 2
Lift Speed (mm/m): 0.3
Can somebody help me???
I haven't used the Chinese resin...but I'd take down the layer exposure to 10sec...6sec of you have the 40w printer.
It seems to me that if you get stuck to the fep you either have too weak supports...or over exposure.
Those numbers are based on me using 0.03 layers and senertek cast resin.
Good luck
//O.
Good luck
//O.
