- Power supplies
- Z-Axis and Tilt assemblies
- etc..
paul
Postby paul » Sat Feb 25, 2017 10:09 pm
Deaner3D
Postby Deaner3D » Sat Feb 25, 2017 11:59 pm
russiangems
Postby russiangems » Mon Feb 27, 2017 3:12 pm
The ribbon cable does a 90 degree turn and goes into the case and connects to the small circuit board. Now if this ribbon cable is broken you will need a new LCD display.
malamen
Postby malamen » Tue Feb 28, 2017 2:46 pm
Has anyone used Nextdent or formlabs resin?I need adjasments for them, thanks
mandrea
Postby mandrea » Thu Mar 02, 2017 5:08 pm
Good news on the front " Z axle ": I modified the shaft with a pitch 2, I added a screw anti backlash with amazing result, no more waving effect ...
Deaner3D
Postby Deaner3D » Fri Mar 03, 2017 12:13 am
ok so which of you glorious bastards prepurchased the "Pro" version shipping in a couple weeks?
Cabo
Postby Cabo » Sat Mar 04, 2017 5:28 pm
Hi mandrea,
Can you tell me or link me to the parts to upgrade the lead screw and the backlash nut.
Thanks.
mandrea
Postby mandrea » Sat Mar 04, 2017 7:18 pm
mandrea
Postby mandrea » Sat Mar 04, 2017 7:42 pm
I modeled this 1 cm thick, to be placed above the engine, because the joint hit the end stop sensor
VDNKh
Postby VDNKh » Mon Mar 06, 2017 8:04 am
Anyone have ever tried FunToDo SnowWhite or DeepBlack resin with this printer?
