- Power supplies
- Z-Axis and Tilt assemblies
- etc..
Dr. Woo
Postby Dr. Woo » Sat Mar 18, 2017 10:15 am
malamen
Postby malamen » Sun Mar 19, 2017 8:49 am
hello everybody.i have got this piece of crap.It does not work((( Lsd does not work/i can see only backlight....
and no picture on lsd (raspbery version)
mandrea
Postby mandrea » Sun Mar 19, 2017 2:37 pm
Dr. Woo
Postby Dr. Woo » Sun Mar 19, 2017 2:46 pm
@mandrea: Thanks for the info.
Have you tried a shorter cure time?
UV LED light source is standard/unmodded (2x10 Watts) or hacked/improved by any means?
That 32 mm wave you've mentioned, along which axis/direction? Mind to post a close-up/macroshot?
malamen
Postby malamen » Sun Mar 19, 2017 3:09 pm
why does motor cannot lift the platform.As if it is glued to the tank.and there is a strange noise from motor...and i can see thaat platform is rising only at one end-nere to the scrue...i have used the rezin that came with the printer....60 sec 2 layers and others 8 .but it cannot lift.....maybe thre is no teflon on the bottom of tank
Dr. Woo
Postby Dr. Woo » Sun Mar 19, 2017 3:40 pm
malamen
Postby malamen » Mon Mar 20, 2017 4:23 am
i understand this. but the object which i print is small.(should be small)).And i cannot understand one thing.I get stl file in to workshop. save swg file .And only after that i slice it. so how will it change the file i saved before?
Dr. Woo
Postby Dr. Woo » Mon Mar 20, 2017 5:28 am
I can't guide you through Creation Workshop. You should start a new thread with a meaningful topic title in the and ask the question there (this here is the Hardware Forum).
If your object is small, but the entire buildplate gets cured as shown in , it means that you are doing something wrong. Check your sliced images: I assume that the first layers (if not all) are all entirely white. But again: Post your question in the CW Forum!
malamen
Postby malamen » Mon Mar 20, 2017 6:31 am
no, i can see the imagej n the screen.i even made smaller curing time...but it cannot lift up .Nd there is not only workshop.There is a soft for raspberry ...But it works if i save image and only after that i slice it....maybe i should plase workshop on disk C....I dont know were to write.The seller cannot help me.The only person is you and i hope you will help me.If it is possible send me your idias to my mail malamenr@mail.ru .Thaks alot!!!!!
Dr. Woo
Postby Dr. Woo » Mon Mar 20, 2017 6:53 am
I'm sorry but I can't help you with your problems. To be honest, although I'm not a native english speaker either, I sometimes have a hard time following your descriptions. I recently accidentally came across a russian language 3d sla printing forum, where they discuss the KLD-1260 in detail. See here: http://roboforum.ru/forum107/topic17010.html
There’s also a russian/ukraine review of the KLD-1260, perhaps they have discussion on that site or you could talk to the author of the review: https://3dprinter.ua/kld-lcd1260-review/
