Some detail of the rook.
check out the the tekst.. how sharp it is
- Joined: Sun Dec 04, 2016 12:55 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Very nice, how is made FEP anchorage in the vat?
Hi Odd,
7 seconds was my lowest, i might try 6.8 but i fear thats the lowest I can go with Industrial blend Fun-To-Do
With the printer 1 fep sheet is provided.
anything happening with the raspberry pi I will share
Cheers,
Cheers,
- Joined: Mon Dec 05, 2016 4:53 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Pls, post some photo of the vat design
- Joined: Tue Jun 24, 2014 8:14 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
From what I can tell it looks like they used this?
https://www.aliexpress.com/item/5-5-inc ... 8bf8&tpp=1
I'm looking in to making a new high res Daylight printer, my last one can be found here:
http://www.kvistholm.se/Daylight-Resin-Printer
I wish to use NanoDLP GPIO and with a stepstick (no arudino).
My only concern is the stock backlight brightness for this LCD (most likely it will not match the iPad display)?
Also, what would be the settings in config.txt in the raspberry ... (anyone here good in deriving those)?
http://creotech.pl/en/produkt/mipi-dsi- ... adapter-2/
also has a driver that works with LG Optimus e980 (400+ nits) seems nice.
But they don't have the driver in stock ... possibly for 1-2 months =/
PS.
Here are the settings in config.txt for 2 screens (anyone make sense of this)?
For the IPhone4 LCD:
hdmi_timings=640 1 62 14 62 960 1 27 1 17 0 0 0 60 0 48437500 1
display_rotate=1
framebuffer_width=960
framebuffer_height=640
For the E980 LCD:
hdmi_timings=1080 1 46 1 45 1920 1 10 1 4 0 0 0 48 0 108330000 1
display_rotate=1
framebuffer_width=1920
framebuffer_height=1080
What are your thoughts ...
PS.
display_rotate=1
For the E980 LCD:
display_rotate=1
