How I removed my DLP color wheel and destroyed the projector - A sad but perhaps informative tale
- Power supplies
- Z-Axis and Tilt assemblies
- etc..
PuffPed
Postby PuffPed » Sat Mar 19, 2016 5:27 pm
https://lazygeckoblog.wordpress.com/201 ... projector/
TL;DR: I removed the color wheel, but also accidentally re-installed the cooling fan in reverse. The first lens in the optical path melts and explodes. I don't know if it's because of the reversed fan, the lack of a color wheel to block heat, or both.
What do you think?
ryanbahr
Re: How I removed my DLP color wheel and destroyed the projector - A sad but perhaps informative tale
Postby ryanbahr » Mon Apr 11, 2016 11:14 am
I'd have to argue that it is completely the backwards fan. The good news is that if you buy a broken projector of the same model that has the part that broke you should be able to get a working DLP projector again.
