Looking at khwelling's blog he gives a list of possible sources to order som Front surface mirrors.
I've been ordering some stuff on toaboa for awhile now and found a supplier supplying to the US and Europe.
will put in an order of 2 pieces to check the quality.
here is the link:
front surface mirrors
Re: front surface mirrors
I'd like to point out that you can use an old hard driver platter as a front surface mirror. It's pure polished aluminum & free (if you've got old drives).
Hi PacManFan,
thanks i got a few of those in a box somewhere![Smile :)](./images/smilies/icon_e_smile.gif)
i only wonder if the surface of the disk will be big enough.
You can also do what I had to do last night since I broke the front surface mirror I had for my build. :/
Take a regular mirror and strip the paint off the back side, paint the front side and you have a first surface mirror. Not sure how long it will last but it seems to be exactly the same reflective quality as a piece of my broken front surface. Mine you it's a temp fix so I can get my build done and ready to go, I will be ordering a real one just in case.![Smile :)](./images/smilies/icon_e_smile.gif)
- Joined: Sun Feb 09, 2014 4:42 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
you can salvage large first surface mirrors from projection tv's, a little careful handling is required as it is both glass and very prone to scratching the surface you're trying to salvage. I ended up using suede as a buffer between any tools and the mirrors metal surface.
Low cost but not always 100% perfect
http://www.sciplus.com/p/MIRROR-FIRST-S ... -SMALL_248
all under $5ea up to 63MM X 231MM X 9.5MM THK
