Suitable glue (that's not dissolved by resin)
- Power supplies
- Z-Axis and Tilt assemblies
- etc..
Kvirre
Postby Kvirre » Mon May 04, 2015 3:35 am
I am currently using a peristaltic pump to control my resin-level in my VAT.
The pumps tube is connected to rubber hose.
It seems like the fitting between the two is not 100 % sealed, and I would like to glue those together.
I tried "superglue" but it seemed to dissolve and and once again made a mess on my floor.
Is there some kind of putty or glue you know of to make a long lasting seal for my pump connection?
Regards
android78
Re: Suitable glue (that's not dissolved by resin)
Postby android78 » Mon May 04, 2015 5:53 am
I would think silicon would be best.
Kvirre
Postby Kvirre » Tue May 05, 2015 4:36 am
BMMal
Postby BMMal » Wed May 06, 2015 9:03 am
Silicone adhesives will work. I had used silicone to build some all glass vats. With those I did see that some component of the resin is able to permeate through the silicone though resulting in an oily residue on the outer surface of the silicone. A 2 part epoxy or maybe a PMMA (poly methyl methacrylate) adhesive would be even better, especially one intended for bonding thermoplastics.
