Acer K132
- Power supplies
- Z-Axis and Tilt assemblies
- etc..
msbm5
Acer K132
Postby msbm5 » Mon Mar 30, 2015 8:03 am
Does anyone know if this projector emits the right wavelength? Is it a good option? I am planning my first build and it looks good for my budget. Any feedback is appreciated.
Details:
Acer K132 WXGA DLP LED Projector, 600 Lumens
Projection System: DLP®
Display Panel: 0.45" DMD
Resolution: Native WXGA (1280 x 800), Maximum UXGA (1600 x 1200), 1080P (1900 x 1280)
Aspect Ratio: 16: 10 (native), 4:3, 16:9
Contrast Ratio: 10000:1
Brightness: 600 ANSI Lumens(Standard), 480 ANSI Lumens (ECO)
Lamp Life: 20,000 hours (Standard), 30,000 hours (ECO)
Projection Lens: F = 2.0, f = 14.95mm, Manual focus
Keystone Correction: +/-40 degrees (Vertical), manual & auto
Noise Level: 33 dBA (Standard mode) / 29 dBA (ECO mode)
Input Interface: HDMI/MHL (Video, Audio, HDCP) x 1, Analog RGB (via Optional 24-pin Universal to VGA cable) x 1
Control Interface:USB (Mini-B)
Weight:.91 lbs. (system unit only)
adambx
Re: Acer K132
Postby adambx » Mon Mar 30, 2015 11:44 am
you would have to mod it to use an UV LED. If it's your first build and you're not experienced with electronics i'd highly recommend to go with a traditional Projector, WXGA projectors are cheap enough.
try the Acer X1373W. It looks like a H6510BD but with a lower resolution. And it costs as little as the K123.
Cheers ^^
