I'm trying to assemble my electronics, I got Marlin to install into the RAMPS board, got the LCD working. But I can't get the stepper motor to work. I assuming the motors should lock up once the board is powered up? I tried to move the driver and motor to the other axis (X and Y) but it still freely turns when I power it on. I put all 3 jumpers to make it 1/16 microstep. The pot on the stepper driver doesn't have an end limit, freely turns counterclockwise forever. Is there anything I'm missing?
can't get my steppers to work (RAMPS 1.4/Marlin)
- Joined: Sun Feb 22, 2015 3:35 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Re: can't get my steppers to work (RAMPS 1.4/Marlin)
I figured it out. I was using the round AC adapter plug on the Mega board, I cut up the plug and attached the power directly to the terminal screws on the RAMPS board. Was the stepper motors are able to lock up when activated.
Thanks[/quote]
hey, how did you get the 1/16 microstep using jumpers (?) ? will you please tell me !! its better if you post pics of it too
thanks
Thanks[/quote]
