I'm certainly not an expert in the field, so don't take anything I say as gospel. I'm having trouble finding the original piece I read about it, but I did find this: http://focus.ti.com/download/dlpdmd/2503686.pdf. There's one relevant line, "Note 2: UV-optimized DMDs must be carefully controlled in terms of manufacturing process and illumination power spectral content. Usage below 350nm will rapidly degrade lifetime."
So there may be more leeway than I thought, as long as you don't get to close to 350nm?
uv led
Re: uv led
Very interesting, thanks guys.
I still haven't had a chance to do any resin curing tests on my conversion, but I'm now thinking it's good that I have a 400 nm in there. I first tried 365 nm and couldn't get that to transmit through the system. My next try was 400 nm and that transmitted very well, but I had thought about trying other frequencies between 365 and 400 to see what I could get away with. So now, in light of this discussion, I think I'll just stick with the 400 nm.
- Joined: Tue Apr 22, 2014 7:45 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Re: uv led
Hi PacManFan,
Hi James,
rapidly, I let you a link about DMD in UV applications :
other stuff :
Hi James,
other stuff :
