I need a code for optical endstop to buy from a vendor. Because they ask me a code for it.
Thanks in advance,
Any optical endstop suggestion?
Re: Any optical endstop suggestion?
Not sure what you mean by a code. This would be a change in firmware, probably the Z-Axis endstop invert flag.
- Joined: Tue Oct 07, 2014 9:01 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
omron ee-sx674
they are quite expensive from normal channels but you can find then for cheap on ebay
- Joined: Fri Jan 23, 2015 6:15 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Thanks for your suggestion.
