lcd projector
- Power supplies
- Z-Axis and Tilt assemblies
- etc..
johnnyfortner
lcd projector
Postby johnnyfortner » Tue Feb 10, 2015 8:46 pm
Created an account just so I could show this to you guys.
http://www.instructables.com/id/homemad ... /?ALLSTEPS
looks promising, would something like this work at all with uv leds? if not what kind of modifications would it need?
also I'm a little under informed about gcode controlling the whole set up(motors) and with an lcd printer would you just display svg layers? you could even have a hand operated printer with no gcode, just display svg layers with a stopwatch and then turn a handle to raise/lower the build plate.
Re: lcd projector
Postby PacManFan » Wed Feb 11, 2015 12:35 am
You're going to need a DLP projector generally. LCD's don't usually work well.
-S
johnnyfortner
Re: lcd projector
Postby johnnyfortner » Wed Feb 11, 2015 2:47 am
http://bucktownpolymers.com/zve200-v470.html
I found this and it states: Sensitive enough to cure by the blue light from standard unmodified Pico and Pocket sized LED projectors.
so when you have a projector that can cure resin out of the box, the next step is getting the projector to display the right image. how is that done?
PomeroyB
Re: lcd projector
Postby PomeroyB » Wed Feb 11, 2015 2:50 am
