I would be very interested in knowing what projector this is too. Can you post more pictures of the chips and circuit boards? Also, I think I see a USB port on the back. Can you plug it into a computer and see what the VID/PID of the device is?
On second look, it appears the top board is a custom control board. My assumption is that the UV LED control is on this board - indicated by the wire to the DLP portion. I also see another cable going to the button pad to control On/OFF and other functionality.
What this projector
- Joined: Mon Dec 22, 2014 11:22 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Re: What this projector
Hello HP,
Very nice modules... Could you tell us whats model is it?
regards!
regards!
hi Guest2003, vsegobia,
i buy the projectors here:
with the right drivers you can also control the brightness and on off switch of the projector via software.. its pretty cool
kind regards,
kind regards,
