Hi!
My DLP projector produces very little lumens after I spend the calibration of brightness and mask generation. For example, the need to cure the polymer 800, the projector 350 outputs. The lamp is new.
If you know of such a problem, please tell me, what's the reason?
kind regards
low ANSI-lumens
- cncbasher
Re: low ANSI-lumens
you do not give details of your DLP Projector or details of the polymer
has this worked in the past and has developed this problem , or are you trying to match a projector etc ,
one thing to look for are additional filters and is the optic path clean etc , lamps do develop low light levels over time , but again i'd need details of the DLP
it's not so much lumens i.e brightness level , as being able to project the correct light range to match your resin .. i.e UV @ 405nm if the resin is sensitive at that
the actual light level at that point will determine the time of exposure required , lower levels require longer time per slice
let me know some more details and i'll try and guide
Stasey
- Joined: Wed Dec 03, 2014 12:58 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Re: low ANSI-lumens
Hi, cncbasher! Thanks for the answer.
What details you want to know? this is my first problem, and I do not know where to begin to solve it
- cncbasher
Re: low ANSI-lumens
i'll pm you
Stasey
Re: low ANSI-lumens
the problem was resolved. topic closed.
