- Power supplies
- Z-Axis and Tilt assemblies
- etc..
Wabbe
Postby Wabbe » Sat Aug 30, 2014 12:11 am
Postby PacManFan » Sat Aug 30, 2014 12:18 am
Alright, I'm going to have to put in more debugging and get you another test build tomorrow. It looks like it's finding the interfaces correctly, but not connecting for some reason. Did you uninstall the previous driver and install the drivers I provided? What is your system configuration - Win 7 -8? I don't have Linux support through mono quite yet.
Wabbe
Postby Wabbe » Sat Aug 30, 2014 12:35 am
Wabbe
Postby Wabbe » Sat Aug 30, 2014 12:55 am
Back in business! I wiped out all the old driver files again and reinstalled yours. Looks like one didn't update or overwrite. Mirrors are moving now! Now working on why the laser isn't turning on :) Thanks!!
Postby PacManFan » Sat Aug 30, 2014 1:02 am
Which laser output are you using? You should connect to the 'c' output. This is something that I haven't tested yet, I haven't got a ttl output connected on my setup.
Wabbe
Postby Wabbe » Sat Aug 30, 2014 1:05 am
Wabbe
Postby Wabbe » Sat Aug 30, 2014 10:59 am
Looks like the 'c' output has voltage along with 'a' and 'b'. It's shutting the laser off, but will not activate it. Tried it on all connections with the laser turning off. Once I remove the connections the laser turns on.
Postby PacManFan » Sat Aug 30, 2014 11:40 am
Postby PacManFan » Sat Aug 30, 2014 12:13 pm
saviowong
Postby saviowong » Sat Aug 30, 2014 1:59 pm
