I have problem with the printer.
The seller said "The software works with the LCD light. I told you use this software and dry run the printer. Then it works."
But there isn't image on LCD during printing.
https://www.youtube.com/watch?v=kNJ_QeF9aY8
Do I understand correctly the problem in the printer?
malamen
- Joined: Sun Feb 12, 2017 10:21 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
I have the same problem.No image on display! I have ordered new display card....Hope it is the problem.
malamen
I did not order it yet.I am trying to negotiate with the seller.It is James
paul
- Joined: Sat Jan 07, 2017 10:27 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
https://www.aliexpress.com/item/High-pr ... 40996.html
any idea of 40 watts LED ? will it be faster ?
ACA_General
- Joined: Fri Mar 31, 2017 6:54 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
